    • 1. Oktober 2020 um 9:50 Uhr - Views: 940 #8803
      ict_bwzr
        I am currently performing a migration from otrs6 to otobo.
        When i follow the procedure document, there appear to be some parts missing.
        In step 2 it says: … execute the following commands: …
        and then no commands follow
        Can anyone provide the commands that are needed?
      • 1. Oktober 2020 um 10:21 Uhr #8804
          Dear ict_bwr,
          thanks for your request!
          Yes, you are right, we had a bug in the script which generated the documentation. I fixed the bug and created the documentation new for you:
          https://doc.otobo.org/manual/installation/stable/en/content/migration-from-otrs-6.html
          I hope now everything looks fine.
          Thanks for your help!
      • Otobo 11.1. Beta 3
