17. Januar 2023 um 5:29 Uhr - Views: 1427 #14558
Hello, I want to create two links one for customers ( https://helpdesk.company.local ) and one for agents (https://otobo.company.local ) but I can’t set up forwarding from https://helpdesk.company.local to default page
https://helpdesk.company.local/otobo/customer.pl
I use docker installation + nginx as frontend web server. Rewrite rules doesn’t help.
21. März 2023 um 16:21 Uhr #14950
Hi grumpy_kot,
What error are you getting or what exactly says the nginx is not working?
would you like to share your configuration with us? i have set up a nginx and an otobo for testing. It seems to work for me. Here is an example with a very minimalist configuration:
server {
listen 80;
server_name customer.test.local;rewrite (^/$) /otobo/customer.pl permanent;
location / {
proxy_pass http://localhost:8080;
Best regards,
~ kps
14. April 2023 um 8:25 Uhr #15063
My customer part of otobo nginx config ( Otobo start in docker, but nginx installed from apt debian).
I don’t understand .. It doesn’t not works, I tried second way, but it does not work too. (in comment #)
http {
server {
listen 443 ssl;
server_name helpdesk.mydomain.com;
access_log /var/log/nginx/helpdesk.mydomain.com.log;
error_log /var/log/nginx/helpdesk.mydomain.com.log;ssl_certificate /etc/nginx/ssl/fullchain.pem;
ssl_certificate_key /etc/nginx/ssl/privkey.pem;
ssl_session_timeout 5m;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_dhparam /etc/nginx/ssl/dhparams.pem;
ssl_ciphers ‚EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH‘;
ssl_prefer_server_ciphers on;
ssl_session_cache shared:SSL:10m;# location = / {
# return 301 https://helpdesk.mydomain.com/otobo/customer.pl;
# }# if ( $request_filename = / ) {
# rewrite ^ https://helpdesk.mydomain.com/otobo/customer.pl? permanent;
# }rewrite (^$) /otobo/customer.pl permanent;
location / {
proxy_pass http://127.0.0.1:81;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Real-IP $remote_addr;
14. April 2023 um 9:39 Uhr #15064
Hi grumpy_kot,
maybe you are missing „/“ in your configuration?
rewrite (^$) /otobo/customer.pl permanent;i wrote:
rewrite (^/$) /otobo/customer.pl permanent;in my test configuration that makes the difference ;)
Maybe you need a other browser or need to clean the cache for testing.
Best regards
~ kps
20. April 2023 um 11:13 Uhr #15086
Thanks . It Works!
