Schlagwörter: Elasticsearch, OTOBO
16. August 2022 um 13:54 Uhr - Views: 1483 #13558
Hello together,
when I try to run the elasticsearch migration on otobo 10.1.4 I get the following error:
otobo@otobo01:~/bin$ ./otobo.Console.pl Maint::Elasticsearch::Migration
Use of uninitialized value in numeric ne (!=) at /opt/otobo/Kernel/System/Console/Command/Maint/Elasticsearch/Migration.pm line 98.
Elasticsearch webservice is now activated. If you don’t want to keep it enabled, please disable it manually in the admin interface, after the migration is complete.
ERROR: OTOBO-otobo.Console.pl-Maint::Elasticsearch::Migration-01 Perl: 5.30.0 OS: linux Time: Tue Aug 16 10:54:04 2022Message: Need ID!
Traceback (195867):
Module: Kernel::System::GenericInterface::Webservice::WebserviceUpdate Line: 324
Module: Kernel::System::Console::Command::Maint::Elasticsearch::Migration::PreRun Line: 103
Module: (eval) Line: 465
Module: Kernel::System::Console::BaseCommand::Execute Line: 465
Module: ./otobo.Console.pl Line: 35Elasticsearch webservice could not be activated! Unable to continue.
Error: Died at /opt/otobo/Kernel/System/Console/Command/Maint/Elasticsearch/Migration.pm line 110.Does anyone else has the same error and solved it?
I did a migration from otrs to otobo 10.0.x and then migrated to otobo 10.1.4. I just configured the elasticsearch as written in the otobo wiki and then I also checked if everything is listening on port http://localhost:9200
curl -i http://localhost:9200
HTTP/1.1 200 OK
X-elastic-product: Elasticsearch
Warning: 299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 „Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security.“
content-type: application/json; charset=UTF-8
content-length: 556{
„name“ : „otobo01.gisticketsystem.at“,
„cluster_name“ : „elasticsearch“,
„cluster_uuid“ : „TtpgbfxwSQKudMg48UaDRA“,
„version“ : {
„number“ : „7.17.5“,
„build_flavor“ : „default“,
„build_type“ : „deb“,
„build_hash“ : „8d61b4f7ddf931f219e3745f295ed2bbc50c8e84“,
„build_date“ : „2022-06-23T21:57:28.736740635Z“,
„build_snapshot“ : false,
„lucene_version“ : „8.11.1“,
„minimum_wire_compatibility_version“ : „6.8.0“,
„minimum_index_compatibility_version“ : „6.0.0-beta1“
„tagline“ : „You Know, for Search“
}I also installed both plugins. Do I need to check the admin interface of elasticsearch?
I use:
Ubuntu 20.04.4
Apache
apache2-bin/focal-updates,focal-security,now 2.4.41-4ubuntu3.12 amd64 [installed,automatic]
apache2-data/focal-updates,focal-security,now 2.4.41-4ubuntu3.12 all [installed,automatic]
apache2-utils/focal-updates,focal-security,now 2.4.41-4ubuntu3.12 amd64 [installed,automatic]
apache2/focal-updates,focal-security,now 2.4.41-4ubuntu3.12 amd64 [installed]
libapache2-mod-perl2/focal-updates,now 2.0.11-2ubuntu0.20.04.1 amd64 [installed]
libapache2-reload-perl/focal,now 0.13-3 all [installed,automatic]
