Schlagwörter: Migration Docker
29. Juni 2022 um 13:44 Uhr - Views: 977 #13385
I’m trying to migrate from an OTRS 6 Community installation to OTOBO installed with Docker, but I’m stuck at the first step with following message:
Check if OTOBO and OTRS connect is possible.Can't open Kernel/Config.pm file from OTRSHome: /opt/otrs!After a quick check-up in the web container, I can see that the package
sshpassis not installed in the container, thus the migration cannot work…It is pretty hard to install packages in this image. I think this package should be present in the image to fix the issue.
A possible workaround for the moment is to create a new image from this one including the package. It is not really a big deal because the migration should be done once by install, so at the first update the image will be reset but it is ok.
I though you’d like to know about this issue.
4. Juli 2022 um 16:47 Uhr #13398
Hi Lucas,
yes, making the OTRS data /opt/otrs available in the container could be done with
sshpassorsshfs. However the recommended approach is to keep the OTOBO containers as much encapsulated as possible. Therefore we recommend to simple copy the OTRS data into the volume /opt/otobo of the containers. But this is basically a matter of taste, as of course working with mounted volumes already violates encapsulation.See https://doc.otobo.org/manual/installation/10.0/en/content/migration-from-otrs-6.html#optional-step-for-docker-make-required-data-available-inside-container for the recommended approach of copying /opt/otrs into the container.
Best regards,
Diese Antwort wurde vor 2 Jahren, 4 Monaten von
Marc Nilius geändert.
