Ansicht von 1 Antwort-Thread
Schlagwörter: Survey
We are using the Survey module. We are experiencing the following problem:
Is it a bug, or is it a configuration issue?
Dear Gcser,
thanks very much for your request!
I think that is a bug. Please, can you open an issue at https://github.com/RotherOSS/Survey/issues?
Our developer try to fix the problem as soon as possible.
Thanks very much for your help!
