16. März 2021 um 16:52 Uhr - Views: 1115 #11074
Hi All,
I’ve just installed OTOBO and everything so far seems to be working, but I’m seeing this error when the nightly OTOBO Scheduler Daemon Cron: TicketPendingCheck runs:
$ sudo cat SchedulerTaskWorkerERR.log
Use of uninitialized value in lc at /opt/otobo/Kernel/Output/HTML/Layout/Template.pm line 112.
ERROR: OTOBO-otobo.Console.pl-Maint::Ticket::PendingCheck-69 Perl: 5.30.0 OS: linux Time: Tue Mar 16 15:00:05 2021Message: There was an error executing Execute() in Kernel::System::Console::Command::Maint::Ticket::PendingCheck: Use of uninitialized value in lc at /opt/otobo/Kernel/Output/HTML/Layout/Template.pm line 112.
Traceback (3824):
Module: Kernel::System::Daemon::DaemonModules::BaseTaskWorker::_HandleError Line: 60
Module: Kernel::System::Daemon::DaemonModules::SchedulerTaskWorker::Cron::Run Line: 186
Module: (eval) Line: 383
Module: main::Start Line: 383
Module: /opt/otobo/bin/otobo.Daemon.pl Line: 162Line 112 of the Template.pm file is referring to https:
# otobo.psgi seemingly does not set REQUEST_SCHEME
112 $Self->{EnvRef}{REQUEST_SCHEME} ||= lc( $Self->{EnvRef}{HTTPS} ) eq ‚on‘ ? ‚https‘ : ‚http‘;I am running this on apache with a redirect from http to https. I’ve tried setting the HttpType in the system config Framework|base from http to https but I still see this error when this task runs.
Anyone have any ideas on how to fix or what could be causing it?
Thanks
16. März 2021 um 17:50 Uhr #11075
Hi Christopher,
this is a regression, of a too quickly made fix to a psgi specific problem we had. It will be fixed in OTOBO 10.0.10, if you need the fix sooner (and since you are having a look at the files already anyways), please find the necessary changes here: https://github.com/RotherOSS/otobo/commit/6d0bd4ab04dd0e078c2bda3b4162944bc7d48fd3
Best regards, Sven
16. März 2021 um 19:10 Uhr #11077
Hi Sven,
Thanks, I’ve been combing thru all the various OTRS/OTOBO forums for a solution. I’ve edited the Template.pm file with your changes.
Is there a way to manually run the TicketPendingCheck task without having to wait until the cron job runs it in the morning? If I can run it sooner, I can mark this resolved.
Thank you for your help. I was looking at setting up OTRS 6 originally, but saw the post from them that they were discontinuing the free version of it and switched over to OTOBO instead. I’ve set it up for me and 4 other IT guys here to keep track of tickets and such. I’m also going to be using the ITMS feature as well. A couple of integrations I’m looking at is to integrate it with Zabbix5 and Mattermost for notifications.
