18. Juli 2025 um 23:46 Uhr - Views: 434 #35568
Good day,
I’m currently evaluating my options for the future of my service desk.
I’m wondering if a Znuny 6.5.x (latest) to Otobo is still an option?Best regards and thanks for any responses.
21. Juli 2025 um 7:35 Uhr #35569
Hi Jay,
Znuny 7.x is also available. However, we use Otobo ourselves. Both systems are quite similar.
Otobo can be installed out of the box as a Docker. The user interface colors of both systems are different.
https://www.znuny.org/de/blog/gui-preview
Greetings,
22. Juli 2025 um 8:37 Uhr #35574
Thank you Marcel,
I believe my original question was not phrased very wel.
I’m currently on Znuny 5.6.
I am asking if a Migration to Otobo is still possible?, or if the database schema is not supported for a migration. -
22. Juli 2025 um 9:17 Uhr #35575
Hello Jay, I have no experience with this.
I think Znuny 5.6 is based on OTRS 6.0 and you can used the following manual.
https://doc.otobo.de/manual/installation/11.0/en/content/migration-from-otrs.html
Can you setup a second system (example: VM Clone or Backup Restore) and test the migration.
