Schlagwörter: Dynamic Fields
    • 17. Februar 2022 um 16:26 Uhr - Views: 985 #12681
      Chris Viteri
        Hi everyone!
        I have a question regarding dynamic fields in otobo,
        I have successfully created some dynamic fields and they are visible at the customer portal
        However, I wanted to make some customizations to a specific dynamic field.
        Inside the CustomerTicketMessage.tt I followed the instructions to make Fixed dynamic fields with:
        [% RenderBlockStart(„DynamicField_Field 1“) %]
        [% Data.Field %]
        [% IF Data.Tooltip %]
        <i class=“ooofo ooofo-help“></i>
        [% Data.Tooltip | html %]
        [% END %]
        [% Data.Label %]
        [% RenderBlockEnd(„DynamicField_Field1“) %]
        Replacing Field1 with my dynamic field name, but nothing happens
        I tried the same thing with an old otrs 5, and by doing this procedure it works.
        So I don’t know what I am missing here.
        I appreciate your help.
        Regards
