15. Mai 2025 um 11:48 Uhr - Views: 599 #35199
Hi, i’m facing a redirection loop after updating from version 11.0.8 to 11.0.9.
Right after login Agent is faced with a page where you have to click on a link to accept changes: https://xxxxx/otobo/index.pl?Action=AgentInfo;Accept=1
Clicking on the link causes a redirection loop. What have I missed in the upgrade procedure?
loop:
xxxxxx - - [15/May/2025:11:00:34 +0200] "GET /otobo/index.pl?Action=AgentInfo;Accept=1 HTTP/1.1" 302 240 "https://xxxxxx/otobo/index.pl?Action=AgentInfo" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.6 Safari/605.1.15"
xxxxxx - - [15/May/2025:11:00:34 +0200] "GET /otobo/index.pl?Action=AgentInfo;Accept=1 HTTP/1.1" 302 240 "https://xxxxxx/otobo/index.pl?Action=AgentInfo" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.6 Safari/605.1.15"this is how the upgrade has been done:
as root
systemctl stop postfix
systemctl stop apache2
systemctl stop cronas user otobo:
cd /opt/otobo
bin/Cron.sh stop
bin/otobo.Daemon.pl stopas root:
cd otobo-install/
cp -r otobo-11.0.9/* /opt/otobo
cd ..
cp backup/Config.pm otobo/Kernel/
/opt/otobo/bin/otobo.SetPermissions.pl –skip-article-diras user otobo:
perl /opt/otobo/bin/otobo.CheckModules.pl –list
/opt/otobo/bin/otobo.Console.pl Admin::Package::ReinstallAll
/opt/otobo/bin/otobo.Console.pl Admin::Package::UpgradeAll
/opt/otobo/bin/otobo.Console.pl Maint::Config::Rebuild
bin/otobo.Daemon.pl start
bin/Cron.sh startas root:
systemctl start postfix
systemctl start apache2
systemctl start cronregards
15. Mai 2025 um 12:17 Uhr #35200
Hi Carlo,
this is a regression of the latest patch which was overlooked. I just fixed it in the code: https://github.com/RotherOSS/otobo/issues/4342 We will plan another patch, asap.
To fix it on your side before that, please either directly swap the affected file on your system. (Download it from github: https://github.com/RotherOSS/otobo/blob/rel-11_0/Kernel/Modules/AgentInfo.pm (or
wget https://github.com/RotherOSS/otobo/raw/refs/heads/rel-11_0/Kernel/Modules/AgentInfo.pm) and just copy it to your Kernel/Modules/AgentInfo.pm.) Or alternatively temporarily disable the AgentInfo functionality by running the following Console command, which will reset the SysConfig setting:bin/otobo.Console.pl Admin::Config::Update --setting-name 'PreApplicationModule###AgentInfo' --valid 0Sorry for the inconvenience, Sven
15. Mai 2025 um 15:10 Uhr #35201
Thanks editing AgentInfo.pm worked
