Schlagwörter: slow login https http docker
21. Oktober 2024 um 16:32 Uhr - Views: 650 #32498
After I successfully migrated to OTOBO 10.1, I noticed that the login was very slow. It takes about 6 seconds. I tested that it depends on the “Settings” on the right, that is, how many widgets will be displayed on the home page. If I reduce the number of widgets, it speeds up tremendously. I have no problem with this on the OTRS 6 community edition, and it works much faster, but I don’t use HTTPS there, so maybe that’s the problem. Does anyone know how to fix this? If I stop “nginx” container OTOBO won’t work either on the HTTP. Does anyone know how to easily turn off HTTPS on an existing docker OTOBO installation?
Thank you
22. Oktober 2024 um 14:12 Uhr #32525
Let’s say I isolated the problem. The problem is in the „Open Tickets / Need to be answered“ widget. It itself takes 6.36 seconds to load. That widget shows only 12 tickets. I don’t know what the problem is.
Help
6. November 2024 um 14:22 Uhr #33198
They make fun of me in the company that I don’t know how to set this up. Can anyone tell me if there is this problem? I work on OTOBO 10.1.
8. November 2024 um 8:35 Uhr #33278
Hello Antelde,
please try a cache delete and rebuild:
cd bin
KR,
11. November 2024 um 9:21 Uhr #33284
Hi
Thank you for the answer!
Unfortunately, these actions reduced loading time only by 1 second, and now the loading of the „Open Tickets / Need to be answered“ widget takes 5 seconds, so I still have a problem.
